I'm just really anal about clean engine bays & stuff. I have 1200 miles til' the 60k powertrain warranty goes bye bye.
Crawled all under the engine, looked at every gasket from below and above.
The engine has not one gasket leak, no buildup anywhere except for the left side between the cylinder banks (under the engine cover).
So if you pop the cover off, look down, and slightly to the left. Or just to the right of the motor mount. There is a good bit of greasy buildup. Can't tell if it's from the head gasket or from the cooling pipe joint.
As some of you know, I keep my engine bay spotless.
Am I just ocd, would you all just ignore it and consider it normal or take it in and demand they fix whatever is causing it?
