im a huge idiot.. deleted stock map
ms6acton
Contributor
2006 Mazdaspeed 6
i thought i read about this in another thread, but after 15min of searching cant find it.
when i was cleaning out all the old maps off my ap i must have somehow deleted my stock map. i kno im an idiot. but i need to take my car in for some service and dont want it going in with a cobb map on there.
so my question is, if i unmarry the ap from my ecu will it go back to normal on its own, and will mazda notice that i flashed it??
If you unmarry the AP it'll go back to stock I'm pretty sure. Then when you marry it back up it'll again ask you if you want to save the stock map IIRC.
awesome, thanks! i was pretty sure that was what would happen, just wanted to hear it from someone else
You need to ask Cobb, but I'm pretty darn sure it will load the stock map from the AP. When you flash the ECU the first time, the OEM map is GONE unless you saved it.
Onelsono did the same thing as you if im not mistaken. He lost the stock map and just unmarried the AP and it went back to stock automatically. Make sure you drive a little with the unmarried AP because they can tell the last time you reset your battery and the likes.
just to let everyone kno that i brought it to the dealer after uninstalling the ap and they didnt say anything
I believe the latest AP Firmware always contains the latest stock map from Mazda. It may not be your stock map, but it is suitable and in some cases may even be better than what you had before.
No one's ever really been able to answer that question for me. As far as I'm concerned, there really isn't any point.
Is it possible the date that the stock version was flashed/updated, is recorded in (or as a part of) the Mazda stock map?
btw . . . it's arrived, so I'm picking mine up & installing it tomorrow!!! yea me!!!
Hey guys, when you install the AccessPORT and it asks if you want to save the ROM, it saves it to the AccessPORT. You can't erase or access this information so there is no danger of deleting it. When you uninstall the AccessPORT it will flash this saved map onto your ECU. If you skipped this step, it will save a "stock" rom back onto your ECU. This is the exact ROM that the factory loads onto new cars. So either way, you are covered.
Travis
COBB Tuning
