shane02pro5
25ish_psi
- New Caney TX
Just wanted to correct this at least in relation to every other check valve I've ever seen and a universal one which is what I have been using.
The larger barb goes to the IM to allow vac and the smaller goes to the purge valve.
Absolutely not. In fact it would be pretty hard to install it the wrong way since the small barb goes to the nipple on the IM just behind the TB, while the larger bard goes to the purge solenoid. You wouldn't exactly be able to use the larger diameter hose on the side going the the IM, or vise versa.
