if you are intersted in my build as well as the other build..
http:// forum DOT mazda 6 club DOT com/speed6-engine-drivetrain/231049-pics-my-motor-build DOT html
I would post the pics here but there are so many pic i just rather give you the link..
Heres are some teasers though
BRAKES
Ported intake and valve cover
ADVAN RZ wheels 19x8.5
after junk was out but still full interior
With junk in car( VIDEO)
Ported head
went to the track over the weekend...
Only was able to make one pass all day will turn the boost up from 19psi to.... looking at 25 psi
I am car 664
Looks awesome. Are the only mods you have in your signature? I may have to bring my car down for you to work some magic!
yeah i wonder too cuz how do u expect to run 25psi on the stock map sensor? also just a fyi, its not always cyl #3 i know MAP had examples up of how overflowing theirs was, but its actually cyl#4 that outflows all others sometimes, people just for a long time thought cyl 3 blew cuz of the balance shaft assembly, but then alot of ppl convinced them otherwise once MAPs results were punblished, since running hotter is one thing for a cylinder, but runnng leaner is running hotterx3 so if there is a failure that is much more probable a cause, i personally would want to get some flow numbers if i got a PnP
Pretty much oh i have a big maf and flash as well.. i also have a few tricks that i did but nothing major... As far as the porting of the intake when i ported all the intakes i have done i have not cut it open or anything and i have gotten the same HP as those that have had a professional P&P!! bring it on down and lets see what you can get done for you!!!
