greendazer
- 2001 Mazda MP3 turbo
is there a way to adjust the idle cause its idling wayyyyy low on my mp3 and any sudden drop of high rpm's it stalls.
make sure you know its the idle. thats probably the last thing you wanna do. check for a vacuum leak first and make sure the car is getting the right amount of fuel too.
the idle screw doesnt change, i dont see why your idle would be affected by that. did you put a part in and that started to happen?
there's a screw on the back-side of the throttle body...it's a standard (flat head) that sits in a hole...if you look on the firewall side, you should see it.
