- '07 Mazda3, True red
holy wow!!!(wow)
That was the main reason I bought it. It is the only unit at that price that will work with our coil packs that has active boost retard. Yeah, you should have programmed in boost retard. No offence or anything, but I kinda thought that was obvious. Terry runs a retard by rpm ranges with his Link, I think his is up to 10 degrees retard at it's max. I think the only time his timing is at normal levels is in the very low rpm ranges, like less than 3000rpm. I'm not sure that I ramamber the settings he told me he was running, but I know he's using retard all the time and not just during detonation.maybe I should have put in some more boost retard.
Because they just shelled out like $3000 for a turbo kit.Why aren't people using it?
