fourthmeal
Banned
I remember that Sport Compact Car tried to resolve this issue a few years back, and got a very perplexing answer.
It all came down to the fact that the weight is most important at the outer rim and tire, and gets less and less significant closer to the hub. This correlates directly with common sense of course. HOWEVER, the actual math involved is incredible, even with just a solid disk and a ring for a wheel hoop. Let alone the craziness involved with spokes and such.
However, you can establish some rough guidelines to help figure out which wheel will impact performance the most or least:
The outer hoop or "rim" matters the most. A lightweight rolled aluminum rim vs. a part of a 1 piece cast wheel...the weight is less with the thin rolled aluminum.
The number of spokes doesn't matter, but the total mass of course, does. If the spokes taper to a wider form near on the outside of the rim vs. a narrow taper form, then the narrow one will have less inertia to muscle around.
The differences are minor, but they are there. However, when it comes to wheels, I'd choose durability as my primary factor if I'm looking for lightweight. You don't want to go to thin and feathery, since they might fail if you hit something hard enough!
