WGA is the Wastegate Actuator. Kind of like the motor that rolls down your window. The actuator is vacuum driven which opens and closes the wastegate using a long rod.
I would check for boost leaks as well... take the intake off and pressurize the turbo through there and listen/look for leaks. It should hold a steady 10psi for at least several seconds and bleed off slowly after that.
