Chris@Hypertech
Never the less i cleared the code and went on with the installation but it keeps telling me there is an update. I have the latest firmware update on it according to the tuner update application. Looks like i will be making a call to hypertech tomorrow.
You may have a calibration in your ECU that we don't support yet. Try updating the programmer again, and it should tell you.
There is a sequence of steps that happens with the Mazdaspeed3 and 6 when you program your vehicle for the first time. Even if you update the programmer to the latest revision before programming, you will still need to update it. The programmer is shipped with a "default" platform. That platform will vary based on the production date of the programmer. Most of the time, you will need to update first, and select the platform that corresponds to your car.
When connecting the programmer to your car for the first time, you will get a message after connecting the programmer that it needs to be updated. The programmer reads out the stock calibration info. We aren't able to copy the stock calibration files from your ECU, so in order to be able to flash your car back to stock, the programmer has to be updated to download the stock tuning files AND the Hypertech tune for your calibration. Once you update the programmer, then you can go back and program your car. If you have a calibration in your ECU that is not supported, then the tuner update software will upload the calibration info to us, and ask you for your email address. Once we have a tune for your calibration, then you will get an email letting you know that an update is available.
Chris
