EnjoyMinuteMaid
I think its pretty good if that makes you feel any better...
BlueBeast22 said:Yeah I just ordered the 6psi atp WGA, and I need to know how to install it without removing the turbo/manifold.
Alejo_NIN said:actually, you are right....i did not need to remove the mani when i did it on a friend's MSP...he was there to push the actuator...still, you need some very good pliers to get the ******* pin in....even tho when i removed it it broke...
so i just out some chicken wire around it...(it happened to me too on my car, same fix)
maybe i went thru too much s*** to change mine, but i found that to be easier keeping in mind that i was alone..
hey jdm sam, whats the difference if i get the rods or not? im gettin the wga for sure, just wasnt clear on the difference of getting the rods or not...JDM Sam said:
Alejo_NIN said:do not get the rods...there is no point as it is a direct replacement
gotcha....ordered and shipped yesterday, they work fast! my vacuum is staying at 18-19...do you think it could be the colder weather thats bringing down the vacuum and the reason why its spiking to 10 when i had it set to 8.5psi?Alejo_NIN said:yea, it'll just complicate things...hey...the atp will give you a free pound of boost
Kansei said:here's the clip that holds the rod onto the wastegate:
if that helps you understand how to take it off any better.
MSP608 said:picture wont work
