Sorry, I haven't checked this for a while, didn't mean to leave anyone hanging. No pics, my bad, hadn't intended to make a how to, just started writing. If you need em, open your hood and take some, it's all right there staring at you, at least as much as most other serp belt setups you see anymore.
If I recall correctly I took the through bolt that held the tensioner onto the front of the motor out, then took tensioner to bench/vise and took out pulley bolt where I could get at it. Pretty straightforward as I remember it.
Since a few people have liked the idea of getting smacked in the melon with a long screwdriver when it gets caught in the belt when you're listening to bearings, here's a similar way to have your whole forearm cut off, or at least a couple fingers. Don't laugh, could happen, probably has sometime, somewhere. If you don't know what you're doing, don't attempt this any more than you would try Russian Roulette, you don't do 2 out of 3, you lose once, instant fail.
VERY FIRMLY grasp a regular wooden handled wire brush, the kind you'd use for scraping paint off the barn, with both hands, find an open spot somewhere between pulleys, and firmly press the wire ends up against the grooved side of the belt with the engine running. Does a great job of deglazing and popping out small rocks and pebbles that can make gawd awful noises as the belt spins. Probably does a small amount of instantaneous wear to the belt, maybe you lose a little life out of it, oh well. Recommend not doing it out in the country alone in case you do cut off your forearm, could bleed out b4 you found help.
