I bought my ssqv used. Little did I know buddy previously must have had this on a turbod submarine! Geez. I had fluttering noises and didnt know how I had it set. I suspected the piston was sticking a little bitso without further ado.
<o =""></o>Howto:
<o =""></o>Take apart and clean your SSQV.
<o =""></o>
Tools needed.<o =""></o>
Steps:
1. Remove the bolts holding the front surround. (x8)
2. Remove the bolts holding the back half on.
<o =""></o>
<o =""></o>
4. As you can see the spring can come out completely as the cap will nudge right up to the back half once its gone.
<o =""></o>
<o =""></o>
5. Remove spring cap
<o =""></o>
<o =""></o>
6. Remove spring
<o =""></o>
<o =""></o>
7. Push the front of the piston back to lift the rubber gasket away from the metal and youcan have a look into the chamber
<o =""></o>
8. Spray some wd-40 on whatever components to clean the gunk off them (I used some C-L-R on the spring and cap and a green scouring pad to get the rust off.)<o =""></o>
<o =""></o>
9. Let sit (if you have some rust). Use a scouring pad, or a brush to remove the excess.<o =""></o>
<o =""></o>
10. Wipe off the gasket on top and underneath.
<o =""></o>
<o =""></o>
11. Spray some wd-40 on the piston. (I was reading that some high temp resistant lube might be better for this, but I only had wd)
<o =""></o>
<o =""></o>
12. Re-assemble
To adjust the SSQV: (you'll need 2 - 10mm wrenches)
1. The back screw has two pieces to it. The adjustment bolt itself and the locking nut that keeps it in place.
2. Loosen the nut to allow the adjustment of the bolt.
3. Settings
<o =""></o>Howto:
<o =""></o>
- <o =""></o>3mm allen key
- 7/32 wrench
- Needle nose pliers
- rust removal liquid (all i had was CLR & WD-40)
- Lubrication oil
- scouring pad
- Thread lock (optional)
Steps:
a) I read somewhere that if you loosened the screw too much youd mess up the spring. As you will see, it would be rather difficult to do so.<o =""></o>
<o =""></o>b) Removing these are a little time consuming and can be a bit of a pain, but they will come off. I think they have a little thread lock on them.
<o =""></o>c) I removed the bolts in a alternating pattern till I had only 3 bolts really holding it together, just incase it were to spring open and mess up some internal component. I was just being cautious (nothing wrong with that), but you can see in the pictures what inside looks like.
3. Open the halves
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
6. Remove spring
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
<o =""></o>
12. Re-assemble
3. Settings
a)Loosest setting is with the longest amount of bolt seen. More bolt outside the chamber, the less compression on the spring.
---Softer setting means that at lower psi the chamber wil release easier. you'll hear more pssshhh at lower lesser loads.
b)Tightest is with the least. Less bolt showing = more bolt compressing the spring inside
Hope that's helpful!---Tighter setting means that at it takes higher psi to activate the release resulting in less psshh at lower loads, but a higher louder shriek at higher psi.
