How To: Paint Brake Calipers
MyReDpR5 said:
Ok, I've got a Red PR5 ... I am wanting to paint the calipers, but am unsure what color.QUOTE]
I've got a red p5 too and I got the red G2 caliper paint. I am painting them within the next couple weeks.
I think red would look sweet on your car. If you do go with blue, go with something between the bright blue and navy blue. Get like a royal blue or something.
Natey and Hawaiinnights....what kind of paints did you guys use??
And what color Duplicolor is everyone using for red....I know the cap on "Ford Red" looks orange and someone said it came out orange. What are the names of some other Duplicolor reds.
G2 looks good but is way to expensive.
I also want to do this right. Does Duplicolor make the high heat primer and clear gloss coat? I've never seen any of these or any good colors (damn Ford Red is all I ever see) at my local Murry's.
Where do you get the duplicolor 1200 degree paint?
Let me know
Thanks
Chefs P5
Natey said:
Nope. It took me about three-four hours to put 4-5 coats on all four wheels. Here's an old post of mine ;)
The reason for brushing is that it takes forever to tape everything off. I used a Big Gulp cup with a paper towel over the lid to minimize over-spray(as I filled it up) for my paint cup. Worked great.
To clean the calipers I used a wire-brush drill-bit from Ace Hardware, and my cordless drill. It took about 10min per wheel. Make sure everythings nice and shiny before you start painting.
Another trick that I found is to use a sponge-brush to paint with. The sponge brush won't leave those "lines" that you get after painting with a regular brush. Also it's a good idea to have a couple extra paint brushes around...
One more suggestion: Jack the car up so that you can do two wheels at a time, that way when you're done with one side, the other will be dry and ready for another coat. Back and forth. I did 4 or 5 coats with Duplicolor 1200 degree paint ($4.95)and the calipers look almost rubberized.
(sorry,derrick1623, for the thread-jack)
Well I am looking into this stuff call G2. It seems to really out shine and out last other products out there.
I'm happy with it. It's nice because you don't have to tape stuff off since it's brush on. Also, thicker coats because it's brush on. And it comes with brake cleaner so that's cool too. They warranty it too, since it's designed for brake caliper painting.
Let me know
Thanks
Chefs P5
I didn't get that type, but I think I can steer you in the right direction. I used some Plasti-kote "Brake Caliper Paint". It's suited for both high temperatures and is chemically resistant to brake dust so it doesn't wear off over time.
Go to pep-boys, thats where they had it. They have a bunch of specialty paints there. If not try autozone, they should have it there too (here it was cheaper at PepBoys.)
Here's my story, from another thread:
I painted my brakes (see pics) with Dupont MetalCast paint.
I sprayed the paint, instead of brushing it.
It took about 20-30 minutes for me to mask off the wheelwells, because I had small catalog pages instead of a big newspaper. Advice: get some big-ass newspapers, will make it much easier to mask off the entire wheelwell. Also put some masking tape around the edges where the paint starts. I also put a newspaper around behind the brake, such that the CV joint and all the hoses were covered.
Spray-painted base paint for about 30 seconds, then waited 5 (maybe 10?) minutes before next coat, then another coat of base paint (looks silver). Then waited 30-40 minutes, then spray-painted two blue coats w/ 5-minute interval.
Waited about 1-1.5 hrs before getting back on the road. Total time: 3 hrs tops?
Overall, since I did it in a closed garage, I had little overspray. However, watch out if you are doing it outside on a windy day, watch out, paint is gonna start flying (that's when masking is really helpful). Pick a non-windy day :)
As far as it holding up, so far so good. I do wish that I sanded off the more visible parts of the caliper more, so they would look a little less rough. xxMSPxx sprayed some brake parts cleaner for me, that helped to get the initial dirt off the calipers before I began sanding them down.
Total cost: ~$12 at AutoZone (eh, plus couple of bucks for sandpaper).
I went with the suggestions of some on here and went with red for my calipers. I purchased the kit from Meijer for $15.00 and was pleased with the turnout.
For some reason the pic in the last post showed the caliper as black. ?? Check out my web page for pics of the finished look.
pic was okay . . . good job. I like it. It definitely makes your car look nicer.
if you want to go simple yet classy and sporty looking red is always going to be the best choice.
Well I went with a different color than most people here. I thought about doing red but way too many people are doing red so I went with yellow. I think it looks great on my mp3. Check it out
No doubt, MP3Architect. The yellow looks hot with the blue body color. Nice choice!
nice choice i would have chose the same if i had the laser blue colr, NICE!
I kno this forum is dead, might as well bring it back
I got a black 2000 Protege LX and im getting glossy black rims with chrome lip. i want to paint the calipers, but not sure if I should, and if i do, what color?
well i think if your car is balck, and your rims are black then u should have calipers that contrast and pop out more.
