TXMazdaSpeeder
T is for Turbo
- 2003 Black Mica MSP #566
time for a mazdaspeed brake upgrade
girth said:For the rears on the MSP there is no "set screw" type deal like the regular proteges and you don't even need an allen wrench or anything, so they're actually easier than the fronts. All you do is take the caliper off (easy, just 1 bolt plus the e-brake bolt) and then you'll see that the piston on the rear is a "screw-type" piston with a >< indentation in it. Rather than use a C-clamp to compress the piston like did you do with the fronts, just take a needle-nose pliers and screw the piston in by twisting it clock-wise. It turns somewhat hard so make sure you have a good grip on the pliers and it's a good pair of pliers. Mine took 1 and 1/2 full turns in order to get the clearance needed to slip it over the new pads. You'll need to turn it in 1/2 turn (180 degree) increments because the >< needs to line up with the notches on the back of the brake pad. That's pretty much it though -- they're actually really easy because no retarded "hidden" set screw to mess with.
Pmpkinhead said:Lube everything except the pad surface! Use a small blade or screwdriver to gently scrape the guides clean or buy (recommended) the kit with new guides.
Coat everything with brake parts cleaner and scrape the gunk off the calipers. It can't hurt to buy all new hardware and rubber boots from the dealer...it's only like $10Pmpkinhead said:Lube everything except the pad surface! Use a small blade or screwdriver to gently scrape the guides clean or buy (recommended) the kit with new guides.
