The vac line is only for the boost readout, it doesn't affect the function of the TT. You may have tapped into the wrong wires or not have a good enough connection. I know there are two wires that are the same color in the harness you tap into. Also, to set the alarm while the car is still running you have to cut a blue wire that runs to a white box on the rear deck, behind the rear seats.
