how to install Turbo Timer
Mazda, Mazdaspeed Protege, Orange
If anybody has some step by step installation for a turbo timer on the msp that would help out a lot
I am trying to install mine, but I cant find that connector anywhere. Mine is a 02 Protege 5, I wouldnt think that it is different. I followed the wires out of my ignition and they just start to blend into the main wire bundle.
Any help please.
The connector is right on the bottom of the steering column, that link has a really good picture of it. They are definitely the same on all proteges.
anybody have a good link to install the apexi auto timer? I have mine sitting in the garage uninstalled and would like to but cant find a good thread on it
Question I have the blitz turbo timer but doesn't work properly when I turn off the switch the engine cut off too, my question is, the turbo timer vacuum hose need be connected to work correctly??
Sent from my SM-G900T1 using Tapatalk
The vac line is only for the boost readout, it doesn't affect the function of the TT. You may have tapped into the wrong wires or not have a good enough connection. I know there are two wires that are the same color in the harness you tap into. Also, to set the alarm while the car is still running you have to cut a blue wire that runs to a white box on the rear deck, behind the rear seats.
