- '07 Mazda3, True red
HOW TO: Install an amp wiring kit
the kit contains a power wire, a ground wire, a remote turn-on wire, and RCA jacks
- passenger side of engine bay.
- to the left of where these wires enter(next to the wires but still inside the grommet), you can feel where to go.
- go inside the car, and pop out this cover panel.
- then, pop out the one one the right side...
- after that, pull the carpet down like so...
- then, poke a small screw driver through like this...
- follow that up with something the same thickness as your power wire (i used a bigass lag bolt, but whatever.). tape the wire to whatever you used using a tape that wont hang up...and CAREFULLY slide it through the grommet, you may need an extra set of hands here.
- then, the in-line fuse...
- ok, now just run the other end of the wire all the way to the trunk, to get it under the middle plastic piece, pull it up about a half inch.
- fish the wire under the rear seat bracket, after going under the side of the seat.
- the ground wire is easy. move the stock sub out of the way and pull back the carpet from inside the car...ground it here.
- for the RCA and remote wires, i ran them together so i didn't have to do it twice.just run them like the other side...
