- '13 CWP MS3 & '16 Mazda6 GT
you da man
That will work also. I used a marker that was bright yellow,it's a water market. I painted the mounting tabs on the intercooler with the marker and lined it up to the bottom crash bar and just pushed up and made my marks. Drilled the middle section of the marks and that's it. Worked perfect. It's one of those markers that u use to write on the car windows.Thinking of pulling the crash bar, measuring the mounting points on the bottom. That way I'll just have to drill holes in the bottom and I'll cut out 2 squares on the back side of the crash bar to get access to put the bolts is and mount it.
so what? Cut the bottom section out of the bumper support? So basically the FMIC mounts to the "mid" section of the support? Is that wat you meant?
U dont have to cut your bumper support since your fmic is small in size to fit perfectly fine without hitting the bottom section of the bumper. Bolted back a inch or 2,yes but cut bumper support,not needed
am I going to need a breather for the valve cover?
