The task is not starting on the right track - where is the MAF sensor located on a Protege 2000???
It is located in the air intake tube right after the air cleaner box top cover.
There are 2 screws holding it in place with an electrical connector attached.
Post#11 in this thread shows the air tube and air cleaner housing removed from car but with the sensor still installed in it.
(I did it with the air tube still under hood... just removed the sensor only)
Unplug connector, remove 2 screws... gently lift up and remove sensor assy.
The MAF sensors are actually inside the tube part of the sensor, they are delicate so be careful with the tube on the spray cleaner as mentioned above.
The IAT is easy to see... looks like a tiny blob of amber with 2 wires... go ahead and clean it too... can't hurt!
It took several short sprays to get mine (actual MAF sensors) clean...if held just right you can see the little wire and when it is clean.
Carefully reinstall into air tube paying attention to the O-ring seal and screw back down securely. Plug back in.
Pull battery cable to clear codes and reset ECU, then reconnect.
Start engine, drive... enjoy! (hopefully!) (naughty)
I just cleaned mine today after pulling a P1170 and P1171 code (and the car was running absolutely horrible... thought the auto trans was going out!
Appears to have solved everything!
First time cleaning... I am at 53,000 on a 2000 Proto 1.6 LX
