:bs:
Did the Sea Foam treatment today. 1/3 for the brake booster hose, 1/3 for the crank, and saving the remainder 1/3 for the gas tank later when the tank is not that full. Went pretty smoothly, but didn't get much smoke at all like most people do. Only see a tiny bit, and I guess thats actually a good thing, meaning my MP3 engine is still pretty clean at 80K miles. I did get a CEL, as my dad pour the sea foam really slow, while I am reving the engine. It was fine at first, but the CEL went on about a minute later, when my dad is still pouring...yeah. He went really slow LOL. So looks like if you let the tube suck the sea foam real fast, its less likely the CEL to come on. But no biggy. Just need to disconnect the battery to reset and get rid of it.
I did, right after my dad finish pouring, I let go the gas pedal and turned off the engine for 5-10 minutes, as instructed. Then start it back up and rev it for a few minutes (which is when I would expect a lot of smoke like others, but I barely got any...), then took it for a spin for about 20 miles. I got a couple rough start up, and idle was not as stable, but they slowly went away as I drive it more. It runs pretty normal by the end of that 20 mile drive, as well as the engine start ups as I need to move my cars around to make room for the MP3 into the garage. Maybe pouring/sucking very little bit by bit kept the engine from choking, producing less smoke? Not too sure really.
I did this treatment, but with berrymans b12 instead. That has a following in the contour forums so i figured i'd give it a try. I ran a full can through with some in the crank case and half a can in the tank and after about 100 miles of driving its running so much better. Oil change friday and new plugs and wires and it'll be good to go.
