Mark, was the pm I sent awhile back when we talked not enough? It's really easy. I didn't take pics when I did mine because it probably would have doubled the time it took me to do it. It's 2 nuts on the rear shocks in the back, out come the old springs, in go the new ones and retighten each shock nut.
The fronts are 3 nuts on top of each strut. the 2 bolts that bolt the lower strut to the knuckle. 1 or 2 small bolts that hold the brake line on (can't remember if its 1 or 2 but you'll see the line). once the strut is out, there's a 14mm or 17mm nut that is on top of the strut. Use a spring compressor or you can go about the other way but do it at your own risk. off comes the old spring and on goes the new one and reinstall. super easy process. You'll laugh when you finish at how easy it was.
