How TO: CEL/MIL Eliminator!
so that means we have at least 3 different ones available -- so all you gurus-- whats the best/correct one to use -- i like doing things once if you know what i mean :)
Help :) pick one -- pick one --- hehehehe
The one I posted was supposed to be good for the heat. I asked for a matalized one, but he said they did not have it and said this one should be good.
The little one was mine and I have mine back under the car about were your feet sit. I have the O2 extended due to my setup, so maybe you would want the metalized one to help with the heat resistance if it is closer to the exhaust. The pics I posted are still working great for me and it has been a couple of months, I think.
so basicly -- all three can work as long as it says (1-uF Capacitor ) the difference is -- if i understand right-- how well they stand the heat -- right ?? and it also has to be non-polarized ??
thanks for the help -- i just want it right the first time -- i hate trouble shooting :)
i do know that non polarised is the way to go because you can not hook it up the wrong current direction :)
bonesmp5 said:
which on am i suppost to use --- this one http://www.msprotege.com/vbb300/attachment.php?attachmentid=13069
or an Electrolytic capacitor
i assume they both work but one will handle the heat better :)
I used an electrylitic capacitor...it's small, has a blue cylinder shaped figure, about 1/2 inch size...as far as hooking up the ohm resister...use a .5 WATT, that's what I'm using, and it's been over 150 miles on my car w/o a cel, with the new header on.
this is so confuzing -- some say that this type of this will work but others no that type wont work -- you need this type of that type ----- Damn some one needs to up date this section of the How-too
all it says is a 1-Mohm resistor and a 1-uf Capacitor -- so we go down there only to find that there are at least 3 types of each to choose from and we are left there scratching are heads going ---- OK which one ?? --
So then we come home to has for help in the forum and all we get is different answers -- one says this type works and the other says NO this type works and some say you need a 1/2 watt while others say they have the 1/4 with no problems ----
so can you see how this can be confusing -- i dont want to trouble shoot and if the Mil really works than in the How-too part it should list EXACTLY which part to buy --
anyways -- this is just me venting from not having only one answer -- so peace out and have a good weekend :)
The ones I posted the pics of have been working for me for some time now. I have no CEL and I used to get them everyday. You can make out the PN's from the pic, and if it doesn't work then your only out like 2 bucks. Those will work fine!
can doing the cel fix cause poor gas milage ?????
i had a full take before doing the cel fix -- when it got empty i had only driven 240 miles after the cel fix -- i allways get around 330 when empty --- so why such a big change -- maybe because i reset my ecu ?? well i filled up today so we will see if this continues -- hope not :(
i am actually getting better mileage i noticed. there could be a lot of variables however..
Actually...I have done many tests when it came to Cel & Gas mileage..and when i had the CEL...my gas mileage dropped..noticeabley..But after the Fix...within 2 Tanks fills..i noticed better mileage. Don't forget that the ecu learns..so everytime you reset it..it has to relearn maps and such.
Chas(homework)
P5 Rally said:
i purchased the capacitor and the resisitor that is specified in the wiring diagram on the first page....That will be sufficient, right Acidbbg?
http://www.msprotege.com/forum/attachment.php?attachmentid=10435
I showed the short dude behind the counter at a local electronics shop and he turned around and 10 seconds later he turned around with stuff that looked exactly like the peices in the pic on page 3
http://www.msprotege.com/forum/attachment.php?attachmentid=13069
Yes it will def be sufficient!
But a quick suggestion..is to pull the ECU code..to make sure you know what it is. B/c this cel fix will only work on ECU code..insuffcient cat warmup.
Chas
Chas
what do you mean by this!!? I have not yet installed my header or CEL fix so at this point everything is normal
Ah..sorry..i thought you already installed.
Chas
Ok, Just to get is strait. I bought the 4-2-1 header for my Protege. All I have to do is install the cel/mil fix but also reset the computer. Then I may experience some less fuel economy but as soon as the comp learns I should be fine, Right? Will this happen or does it depend on every car or does it depend how heavy your foot is or maybe all of the above. Well all in all I hope it all works well for me. I am waiting for the Header. It should be in by this weekend from Cali. (headbang) Can't wait.
ill let you know if my lack of fuel economy was because the ecu was learning at the end of my second tank -- about 4or5 days unless the gasmilage sucks again
You could just get the code erased then you don't have to worry about relearning. Some parts places will do it for free.
