- 92 & 16 Meyatas
120 miles for me!
acidbbg said:well let us know if it comes back..
chas
Fai said:Anyone know where I can get the nonfouler in Canada?? i dun see them in auto store like canadian tire
Lord_Zath said:Don't know the code, but the 2nd o2 is located at the end of the header. The exhaust system goes exhaust port -> 1st 02 -> 1st cat -> 2nd 02 -> 2nd cat -> cat-back exhaust.
And the reason it probably didn't work for you is that the 1st cat takes a lot more out of the exhaust stream than the 2nd cat or a hi-flow cat would ever take out...
Lord_Zath said:Agreed. I do think, htough, that the different sensors have different tasks. For example, the first o2 sensor helps the ecu tune the fuel maps and timing. The second o2 sensor helps the ecu make sure the emissions system is working properly.
The resistor works by changing the o2 sensor's voltage from variable (sensing what's going on) to fixed (always reading the same thing). It will work if it's done correctly. But the nonfouler is a much better/easier way to go.
zmepro said:so if i didn't have the MIL it would cut fuel or run too rich?
