HID lighting, why they are illegal
2001 BJFP MT
2016 BMYFS AT
REPOSTED FROM CLUBPROTEGE. ORIGINALLY POSTED ON 10/05/2003.
All rebutals regarding HID retrofits WILL NOT be tollerated as it's been clearly explained that they don't work as intended and testimonies stating "they work fine" are without any scientific basis which means they're WRONG.
NHTSA didn't "discover" HID "retrofitting" was bad after they were in the market, they knew about it years ago. NHTSA just chose not to be proactive about the issue until there were numerous complaints about excessive glare.
Based on CURRENT technology, HID retrofitting is ILLEGAL *anywhere* in the world and will be as long as humans roam the earth. Keyword "CURRENT". This does not necessarily mean there won't be a legal one that meets photometric standards of either UNECE r98 or FMVSS/CMVSS108.
To everyone going apeshit as to why NHTSA is being such an ass about it, you are ignorant. Wait, don't be pissed. You NEED to learn WHY they are illegal first and understand scientific facts before you have the right to comment. In most cases, people who went from "ignorant" to "informed" have no comment.
So now, the basics.
There are several issues as to why HID (or gas-discharge) lighting must be heavily controlled. One of them is the high light flux from the xenon balasts. They are not "brighter", they are simply more efficient at outputing light that meets the 150000 candela limit requirements. Because it is so effective at this, HID headlights' beam pattern MUST have a cutoff. MOST halogen headlights still on the road today do not have a beam pattern cut off due to the inherent characteristics of the SAE/DOT beam pattern design (lots of "scattered" light). Most of the people performing these HID "retrofits" are doing it to older vehicles that have such headlights. So that's one issue.
What's the other one? Fitment of the capsule itself. D2R capsules are NOT designed to be crammed into a HB2,9004,9006,9007,H1,H7 or ANY halogen housing. When you do this, the bulb either doesn't stay in place very well (as demonstrated by many board members here) or is geometrically offset even when it is "well secured". Ok, to understand this fact better, think of your typical maglite where you have the "zooming" feature. When you have the bulb too far out or in, it changes the beam pattern of the light dramatically.
So, here's an example of the BAD results when you just cram bulbs into the wrong housing
there's no need to comment on how fubar it is
this is coming from a P5 with Audi A8 capsules, but the owner chose to use just the xenon capsules and *not* the projector housing... this makes it not "A8 lights" anymore
Ok, now that we understand the number 2 important fact of "why", let's go to the other one. How does the light appear IN the bulb housing itself? We know halogen bulbs uses a filament. We also know xenon bulbs have no filaments are filled with as the name implies, xenon and other trace gases. Ok, so when a xenon bulb is turned "on", the gas gets electrically charged, but based on phsyics (which I basically know nothing about), the electrically excited xenon gases want to move away. This is stopped by the glass capsule. So the effect that we get is an arc that starts from one end of the capsule, curves upward, then back down at the other end. How does this differ from a halogen bulb? A halogen bulb just glows in a cylindrical shape due to the filament and depending on how the filament is placed in the balast determines the geometric position/"center" of the light. So how does this affect the beam pattern when you put in a "misaligned" bulb? Simply put, you get an unpredictable beam pattern that can range from spotty lighting, or just a high beam-like beam pattern. So what about those "dual beam" HIDs? They do nothing but rob you of funds, that's what. How it works is an electromagnet is energized located next to the xenon balast and when that happens, it moves the arc to a different location. Because of the unpredictability in controlling the geometric position of the arc properly, it has NOT been used in ANY OEM application.
So now, the last thing. Most of you will now go "but my beam pattern is fine!" That's good for you. One thing that you can't see is the light distribution in various areas of the beam pattern's light field. For one thing, because of the increased light flux of the HID light, the hotspot intensity has been exponentially increased and therefore the halogen's light housing does not have the ability to control that (redirect) light to safe levels. Other typical places where excessive or insufficient light has appeared is usually at the far left of the light (in the negative quadrant) and at an area at the lower part of the positive quadrant. So wtf does that have to do with pissing people off? Increasing the hotspot also means increasing the glare because the hotspot is where most of the "stray light" comes from. So why is there a hotspot anyway and why didn't they take that s*** out to begin with? Simply not possible because the hotspot is also where the most light is (the light bulb), and also because of the fact that without it, you cannot light up overhead roadsigns effectively. Now as for the light in other areas of the beam pattern, you will either not see as effectively in those areas, or you will have lighting way over the legal limit (limits which were put in place to prevent glare "coming from the corner" and going to someone's mirror).
This is recent, done on a 02 protege ES with HB2 housings:
http://www.msprotege.com/forum/attachment.php?attachmentid=6282
notice that the beam pattern has changed and you can tell already that the increased light flux at the hot spot is causing excessive glare just from the light above the cutoff alone. Notice the major reduction in light at the far edges of the beam pattern. Also notice the reduced amount of light at the very bottom of the wall (if this was shining on the road, it would be reduced light CLOSE to the car). That's it for basic analysis.
So, based on these BASIC scientific facts, there is NO way anyone can argue with NHTSA or UNECE about their decision to making HID retrofitting illegal. In otherwords, you can't convince them to making them legal to use.
Don't give your hopes up. The experts KNOW that HID can be beneficial. So, they are actually working on a SAFE and legal retrofitting method for existing/older vehicles (this is still years away though).
And for you people confused about HID being "illegal", it is not. RETROFITTING is. Any car that has HID installed as original equipment is expected (in America, in the case of Europe and anywhere else in the world, absolutely yes) to be legal and meets all specifications outlined in FMVSS108. But what about safe and proper HID light housings? Does that mean you can put those on a car? It'll be VERY safe yes. But according to NHTSA's weird interpetation of the law, if it's not original replacement equipment, it is illegal. This means whatever comes out of the vehicle must be replaced with the same type. In the case of MANY vehicles with specially designed light housings from the factory, if you break it, you have to replace it with the same kind.
And a little bonus for you all who have attentively suffered through this long post... this is what a PROPER H4 halogen beam pattern based on the UNECE r20 specification should be like (this is from my car and is equiped with Osram Silverstars):
and you think I didn't suffer? I spent an hour writing this!
here's a pic of what a real HID beam pattern should look like... from a European spec 2000 Audi S4 housing (UNECE r98 right hand traffic compliant) using D2S capsules:
very even light distribution, not big blobs of light
and the US-spec DOT VOL HID beam pattern of a 2000 Audi S4:
much more weaker lighting
pics found from this Audi world how-to:
http://www.audiworld.com/tech/ext30.shtml
and for the non-believers of why j-spec headlights shouldn't be used and think all headlights emit a symetrical "blob" of light:
(see attachment)
picture from PS13 Silvia with reflector type housing with HID "retrofit"
<!-- / message --><!-- sig --> __________________
Thanks for the post. I always wondered about a 'solid' answer about HIDs. I believe the Jspec models come with factory HIDs with the dual beam headlights? Idk? Wierd considering our headlights don't have projectors...
Peace
Peace
There are some HID reflector headlights out there like the IS300, older TL's, Escalade, older Maxima's, but the headlights are designed for an HID bulb so the glare is not that bad. I would have to assume the Jspec headlights are designed for HID's, but with a RHD beam.
My mom's 05 Altima has HIDs with just a reflector housing and the shield over the bulb is designed so that it is ok.
Edwin, do you have the OEM BJ protege sedan headlights? I didn't realize they had such a sharp cutoff.
To add a little info to this thread, here's a very good guide to properly aim your headlights.
http://www.danielsternlighting.com/tech/aim/aim.html
I plan on doing this when I get some time to. Maybe tonight :P
I just need to make sure I can back up 25 feet from my garage door. I think there is a parking space directly behind my garage bay but there might be a garden if I'm 25 feet back. If I can do it quickly and unnoticed maybe I'll use a neighbor's garage door (12 garage bays in a row in my building).
saw a honda accord with bright ass blue hids in my rear view mirror. almost made me want to pull the guy over and beat him with a baseball bat.
and THATS the reason why I did not get HID's retrofitted in my Protege.
Im still waiting in hopes that some day someone will make a mass produced projector-HID headlights for Protege's.
Very informative post. Now I get to bust my friend's balls!!!
unfortunatly i think we will be waiting a long time if someone makes them at all. esp. since our car isnt a currently made model.
in the mean time what do you guys think of the silverstar type of lights? i think they are made by sylvania? do they look cheap or have that dumb blue tint to them? and if your gonna swap them out with your headlights maybe the fog lights should be as well, dont want them to look stupid compared to the headlights.
Welcome to the forums!
Anyway, yeah the Sylvania Silverstars have a blue tint on the bulb. If you want just some decent quality bright white bulbs without the gimmick, get Osram Silverstars. They have completely clear glass and great light output. You can order them at a bunch of places online.
The OEM H4 headlights like the one's on the MSP and Protege Sedan have a nice cut off. The H7 headlights of the Protege5 don't, it's two blobs of light - which is actually quite bright compared to other headlights. When I had my P5, I would get highbeamed every once in a while, using just the stock H7 bulbs! But I like the strong cut off on the H4 better.
I really wonder if there is a cap reflector thing (the thing that comes out in front of the bulb) that I can swap for mine. I really want a sharper cutoff. I do love the P5 light output though.
interesting article.
i dont know much about this so i wont argue whether they are illegal or not. you are probably right.
however i am not sure if there really is harm done to other drivers. at least not from the ones in my car. i will pay attention later tonight and see if how the light output looks like against a wall see if i have blobs of light all over the place and what not.
great article though.
true
Yes you are rite there is a sharp cut off on the h4 protege head lights. Call me krazy but it is a very sharp cut off for a reflector housing. It resembles that of a Celica projector. I noticed this when I first bought my 03' 4dr protege. Does this make HID retrofitting legal? No. But I already ordered my kit and I just found this thread. I will install them and see how it works out and let you guys know. And one more thing, my friend and I both bought some cheap xenon bulbs. He had some in a h7 housing. And he said mine were brighter than his. Well that is because his housing scattered the light so much that it was not hitting the pavement. The 4dr protege's reflector is quite good. But it still does not make them legal. But heck I figure if a guy can put his truck six feet in the air and shine his lights down into my lap! Then they should not complain down here in Alabama, where those trucks are a dime a dozen. But that is how it is though. And oh yeah, very nice thread. This is much needed info for a lot of people. I wish I would have seen it before I made my order last week.
ZoomVT and JohnnieblackDX, as long as you have your headlights properly aimed, you should be ok, BUT it is still illegal. So is going 1mph over the speed limit.
The installation of aftermarket HID retrofit kits is illegal in the United States, and it was only made illegal because of a crazy number of complains from people. I think most of the problem is that the HIDs aren't required to be auto-leveling in the U.S., so when you crest over a hill you blind oncoming motorists, though no more than someone with OEM HIDs that aren't auto leveling.
I wanted to eventually upgrade my Protege5 headlamps to HIDs but now that it has been pointed out that they have a poor cutoff, I'll likely just forget about it. I could retrofit a projector into my headlight housing (which looks really good with the P5 housing), but I don't plan on keeping this car forever so it wouldn't be worth it.
Well a guy I know bought the h4 deadlamps and put them on his p5. You can them off ebay with black housing for a decent price. If you wanted to go that route.
