hiboost + mp3
Vulcanon
Laser Blue MP3-T #1242
Ok well, I'm leaning towards hiboost atm for a turbo kit...assuming I get a p5 ecu, my question is whether or not it will throw a CEL for another reason, since I do need to bring it in for inspection and a CEL is a no no. Also, I am able to run the car without a hassle using the mp3 ecu as long as I'm around 4psi right? Is it possible to just kinda turn off the turbo (0 psi) and not worry about it at all?
yeah I know that part, but besides that would there be another reason to throw one since it only really matters during inspection when I'd use my regular ecu anyway
With the HiBoost kit, and an E6X you should be able to keep the MP3 ECU. I am keeping mine, and will have management soon. :D
well it's not driving around that I'm really worried about, it's the fact that I live in NY and if I have a CEL when I need it inspected, it's not gonna pass
You can now get your HiBoost kit with the E6X Haltech ECU. With this, the advanced timing issue of the MP3 is no longer a problem. I will not throw a CEL and you can run 10 lbs safely. You may get the optional boost controller that allows you to set the exact boost you want with the turn of a knob. This is an option that is very inexpensive. Most controllers are around $350 to $500. Ours is only $180.00 and it is fully electronic. It works alot better than most controllers. You can map the boost curve to your own liking.
Juan
what if someone lent u a p5 ecu? -=) would that work? and i donno how ny is.. but in cali.. a turbo kit wont pass visual without a fuggin cyborg number -=(
HELLOOOOOOOOO TURBOKIT ^_^, only a few more weeks of school and then I'll start to become one with the darkside lol
lol yay another turbo mp3. after i get out of this year of school im going to double up on some working so i can add a turbo to my mp3 before next winter
ddogg777 said:
Juan, if the E6X is finished, give us the heads up on it.
I am still working on it. We have just minor details which are being worked between Haltech and me to make it perfect for proteges. I want it as simple as posible, yet with all the features to make our kit even better. I already have one running.
I will let you know inmediately after is tuned perfectly and ready for shipping.
Juan
If you don't eliminate your second cat just relocate your 2nd O2 behind the 2nd cat no cel, thats what I did worked perfect
