Finally started her up after being home for about 2 1/2 weeks after first removing the 'charger belt (less drag on the engine/starter). I also ordered a set of S Drives from a local place, the Toyos were just getting too hard (and close to the wear bars).
Set a new personal low driving temperature (around 25 degrees). Decided to go to Fuel for cars & coffee, while it was a little too brisk to travel all the way into Cincy topless I did go to my storage to pick up the hard top. Cold temps, crappy road surfaces, older Toyo T1Rs and a supercharger meant instant wheelspin whenever I wanted it. Fun times.
When I got home I installed the CarbonMiata seat belt extenders. They went in with no problems, however the seat belts don't retract properly now. I'm going to see if having the belts that accessible outweighs the inconvenience of the retraction issue. I then went about getting the wiring harness together for the new radio. Got that all done only to find out I had no output. Looking at the drawings, I no longer have a power input to the Bose amp. I think I can move an unused wire from another connector in order to fix this but I have to do some more research.
