well 87 it is then. these cars aren't designed to race corvettes and 91 octane isn't gonna get you there any quickerdcbeggs said:If you read in the manual, it says the MP3 will perform the best with 91 octane, but 87 octane atleast.
MP3Architect said:well 87 it is then. these cars aren't designed to race corvettes and 91 octane isn't gonna get you there any quicker
Topher said:no, the ecu gives advanced timing. when you 87 octane, the ecu resets the timing to p5/es timing... so, if you want it to run properly, use high-octane gas...if you switch from high to low, you can hear the motor ping until the ecu retards the timing.
Topher said:NO ******* s***. you can run 87 octane...is it a good idea? the ecu was designed to run high octane gas...it has to adjust to run the 87...and yes, if you were to switch from 91 down to 78, THERE WILL BE A PING IN THE MOTOR until the ecu resets the timing.
why the **** buy a damn car and not run the recommended fuel? that's a waste. sell the car to someone who can take care of it and appreciate it for what it is. if you can't afford the gas, get a ******* hybrid.
Topher said:smart ass...it was a type-o...and yes, it'll run it fine...it isn't good to switch...and honestly, why buy the car if you're not going to put the recommended fuel in it?
Topher said:why the **** buy a damn car and not run the recommended fuel? that's a waste. sell the car to someone who can take care of it and appreciate it for what it is. if you can't afford the gas, get a ******* hybrid.
speed1016 said:I really dont think it with have to get use to. If anything it might run even better,who knows.
