- 2010 Mazda5 GT
Heard the infamous clunking in the rear so I checked one of the endlink bolts/nuts and it was loose. I re-tightened it to factory specs at 40 lbs. and used Loctite (did the same the first time during install) when I noticed that one endlink was more flexed than the other (passenger/right one in the pics below).
Is this normal? Or will this flex back to normal position? Or do I have to re-install and seat the endlink better? All of the bolts/nuts are tight that I could see. Went over all of them with a socket to make sure.
