I have a boost gauge and it usually peaks at 9lbs and holds at 7lbs. Now it goes all the way up to 15-20lbs and once it gets to 10lbs or higher it bucks really bad. I might as well jump out of the windshield! I changed the spark plugs and 2 were blown. That didn't help. Any place I ask no one knows. It isn't throwing any codes either. All the vaccum lines were checked and they are fine. Someone said maybe fuel filter needs changed. I did research on it and it isn't serviceable. What else could it be???
