Help w/clutch issue
jville
2007 MazdaSpeed 6
Well fellas it never fails that as soon as i do something to my car it starts to f*ck up. This time the mani and dp, and now the clutch pedal is pulsating when slightly depressed. Probably a warped flywheel or broken dampner spring on the clutch. I'm taking it to mazda on tuesday (if it makes it til then) but i know they are probably gunna deny any warranty work on the clutch. Anybody have a manual or a know of a good writeup for clutch replacement on Ms6?
Nobody??? Has anyone upgraded thier clutch and flywheel to the ACT or the specs? Which stage and how is it working out??
Right - i have exactly the same thing happening with my 07 Speed6. Mazda have no idea.
I figure it may just be the cluch cable vibrating?
Did you fix yours?
i just replaced my cluth and the flywheel if u need flywheel i got one 11 lb fidanza light FW
