Hey guys. So I have a 1999 Mazda Protege ES 1.8L and it's been giving me nothing but problems. Right now, it's idling very rough. It sits at around 500-600 RPM and flutters up and down. Sometimes it drops very low to like the 200-300 RPM range and everything shakes tremendously. Everything shakes at 500-600 RPM and it drives me crazy, I just want smooth idling. Another thing I've noticed is that the air from the muffler isn't continuous? If that makes any sense? Like it goes "poof poof poof poof" - it doesn't sound to well.
Things I've done to try and fix the problem:
NEW motor mounts
Cleaned MAF sensor and got new one as well
Cleaned IAC valve
Cleaned EGR valve
Spark Plugs
Cleaned throttle body
I've taken it to the mechanic and nothing. No one knows what this is. There are NO check engine light codes. I've checked if there were any plugs out of place. No check engine light that comes on and off. I don't know what else to do. Love the car and all but this is just annoying. A temporary thing that I've done however is to raise the idle speed so it doesn't sit so low. It idles high now with no vibration but I just want to have smooth idle.
If anyone has any suggestions, please let me know! Thanks
NEW motor mounts
Cleaned IAC valve
Cleaned EGR valve
Spark Plugs
