Help please!!!
bdg667
2002 mp5
I purchased a red top battery and when I went to install it the ignition fuse blew out. I've replaced the fuse and it happened again. Do I have a short somewhere? Any answers? Thanks.
Sounds like you do have a short. Why did you install the Optima? Did you have a problem or symptom before?
I doubt this is it, but when I put the yellow top in my old Honda, like a dumbass I didnt realize that the positive and negative posts were backwards from the original batteries. Just a thought.
Yeah, I was going to mention that, but hoped he knew that already. On a rare chance, check the polarity of the battery. I have seen one that was completely backward! Did not blow the fuse, but the car cranked backwards, took 6 hours to figure out.
Thanks. I had the battery connected correctly. I was told that maybe it's not grounded properly....Still don't see that being the case.
I don't remeber but I do not recall an optima being a drop in procedure. Typicly you need new battery terminals and new connections.
Did you?
Did you?
Optima's have top and side mounts so they fit in any car
1sty said:
Not if the factory terminals don't reach either set.
That would be true! Just never had that problem yet and put in lots of them in different cars, but yes I quess that could be a problem.
1sty said:
Do you have the classic size or one of the new ones?
Its about 2 yrs old so I'm guessing classic. The new ones are bigger correct? Or one of the styles is bigger and the normal one is smaller.
I got mine about 8 months ago.. red top from costo.. $90 .. dropped right in.
