help p0069
creedns
manifold absolute pressure barometric pressure correlation. are the map and baro sensor in the same unit? what could be the causes. dash hawk shows map kpa at 183 at idle and 216 while cruising and its flashin so somethins ******. but if the numbers change my map should still be fine i'd think so i need to know where the baro sensor is at. im gettin ****** sick of this
