HELP!! NRG Hood Prop/Damper Kit Install
Metallic36
2003 Mazda6 3.0L Speed Yellow
Alright, so I have the hood props on, but they are not short enough to attach to the hood. How the heck do they extend/get shorter? Is there some secret to getting them to suck in? I tried pushing as hard as I could, still won't budge.
damned if i know, look for a release valve on the side or on the ends. pics?
is there enough hydraulic fluid in them? are they used?
They are brand new. I think I got it figured out though after someone PMed me last night about them.. I just have to raise my hood really high up to put them on, then we'll see.
Just attach them and see if they compress any. They should be a little hard since its for a reg hood (right??) the carbon fiber hood dampers are much easyer to compress. But put it on the ground between your feet and try to compress them, if you cant even do it from that then they might be WAY to strong IMHO.
They're on, but one of the little pins bent and made the damper pop off the ball on one side when I went to close it slowly. They are supposed to be for a CF hood, they are kinda hard to compress.. kinda gotta pull a good amount but not too bad. I got a piece of wire and basically wrapped it around and wired the damper around the ball so that it wouldn't pop off anymore. It split the holes where the pin went through.
Anyone know the actual length of these. I don't see why a set couldn't be made easily.
ok i measured the 1 prop i have in my room. its 20 3/4 inches. i had to take one off cause 2 were 2 much power for the cf hood i have
