rod knock will happen for the whole rpm range and should be there even @ idle, and will get louder as the eng. warms up and the oil thins so it doesnt really act like rod knock but it def doesnt sound good
i know man i hate it!!! and i was supposed to be turboing it todaythat video was painful to listen to. that sucks man. what were you doing when it started making the noise?
i know man i hate it!!! and i was supposed to be turboing it today![]()
but i was jus pullin outa school parkin lot, got up to about 5k rpm b4 i shifted then it started!!
haha no, i let my car warm upwas the engine cold lol..
im not 100 percent sure but i think ima get another used motor, then turbo it![]()
well even if it was the bearing, wont the the part where its connected to the crank shaft be worn as there is no bearing between the piston rod and that part of the crankshaft itself?dude. i'd at least pull the pan to check.. bearings are way cheaper.. than, purchase a used motor, and build it.. or a block anyways(i have a few laying around i could get you for cheap), and then turbo that..
sweet!! did u get a kit yet?lol, sounds like a plan, im going turbo soon also. (2thumbs)
NICE BRO, good luck with thatpiecing my own together. check my sig for the build thread![]()
i was told by a mechanic that if i was to try and fix it, it would cost me alot more than a new motor would run me up cause i would have to pull the engine, get a crank rebuild kit rebuild tha crank and all this other s***..it's not necessarily that there is NO bearing. the damage would be much worse.. but just that it scored the bearing.. the crank is forged. it'll take a bit more damage than the bearing would. without ******* it up.
am i being fed some BS?
