it can only get better (flash)
u spelled thread wrong its thred
you spelled thread wrong the 2nd time, and "U" is spelled you, so there!(wiggle)
And "its" should be "it's."
(iagree)
it should be it is (gossip)
not its
was he right???Don't go by the dipstick, if that's how you came up with 5 3/4. It reads notoriously high in this car. Just dump 6 quarts into the car if you're changing the filter and be done with it.
After I Add 2more Quarts(total 6quarts,4 From Yesterday), On The Dipstick It Was Like Pretty Close To The Max. I Drove It To Work And Came Back, I Probably Spended 1hr On Driving Today, When I Home I Check The Dipstick It Was Like,wow!!almost 1inches Higher Then The Max, I Cool It Down For Couples Of Hrs And Checked It, It Was The Same Result, In This Case, It Was Read Unproperly?? I Mean Car Run Smooth, I Can Tell Dat!!!!
i had been cool it down for over 6 hrs???
cool it down for 4 mins or so
I just put in Castrol Syntec 5W-30 along with Lucas Oil Stabilizer and GODDAMN! Did the engine come alive! Before, it felt sluggish (I was using Royal Purple) after 4k miles and decided on the Castrol and I'm never going back to RP!
go look in the ******* owner's manual before you start posting bulls*** and saying people are wrong.
It says 5.7 liters(6.0 quarts) if youre replacing the oil filter as well.
