Ok so I changed the pads today on both fronts and noticed that the brakes felt somewhat mushy... during the bed-in process I had one run where pedal hit the floor and brakes didnt respond....that put an end to the bed-in process
Obviously this sounds like air in the brake line and I will bleed the lines tomorrow morning - I just want confirmation that this is the most likely suspect.. what bugs me is that I didnt disconnect any of the brake lines so I dont get how air could have gotten into the lines to begin with
I may be missing something as basic as "you push the piston in you must bleed the lines" - the only thing I know we screwed up on is I didnt notice friend who was helping me had unscrewed the fluid reservoir cap and I pumped the brakes to relieve pressure before removing the calipers. Could this have induced air into the line?
Yes this is my first DIY brake job... road I did bed in is behind my house and its a 2 lane divided straight road with no traffic at the time I did the bed-in (may be a rookie at changing brakes but I wasnt being stupid and risking others lives during bed-in)
Any help or confirmation that bleeding the lines should be the first thing to do would be appreciated
Thanks
Thanks
