People, despite all efforts to repair my damaged engine, Ive decided to swap it. I have already spent more than $800 in parts only, while I have a spare engine sitting on my garage that I brought for $700. Will then use those parts to build a stronger engine.
I need some help on what should I take care with it. I will not open the head, i will just throw in the engine.
All I have in mind is:
1. New Engine Oil
2. New clutch
3. Maybe belts? I may use mine instead of buying new ones.
4. Flush coolant lines
5. Clear the intake/exhaust ports on the head.
6. Open the valve cover an check for any dirt/deposits.
7. I will have to replace the crank with mine (already has the hole for the turbo oil line)
8...???
9...???
what else do I have to take care of?
Thanks
1. New Engine Oil
2. New clutch
8...???
9...???
Thanks
