2017 CX5 Grand Touring AWD with ~ 80k, always serviced by Mazda at correct intervals.
It’s a daily commute car and one morning it would crank over (strongly) start running but stumble and die. So far validated fuel pump and its internal to the tank filter all ok and plenty of pressure as indicated by releasing the line to the pump (post key on) and getting lots of pressure released (not measured). Confident that is ok. Was odd in that it seemed like was rich so pulled the plugs and each and every one black as in too rich runing for some time. Smelled of gas when pulling the plugs as well (this was several days since list tying to start). Replaced plugs and similar but better in that it ran a little longer like 30 seconds before dying. Suspecting perhaps a failed open (or partially open) Evap Purge Valve I removed the hose from it to the intake plenum and plugged it. Now it will start and stay running for about 45 seconds and sounds all good then there is a loud clicking in engine bay and stalls. No codes so far.
Ideas?!
Ideas?!
