Heads Up Display resets every drive?
Phoenix
2021 signature
I could be wrong, but IIRC, my 2020 Signature kept the setting for how high up HUD displays. My 2021 resets back to 0 after each drive. Should it be able holding at the last setting. - I know that some settings go back to default, but I didn't this should be one of those.
It's supposed to be tied into the seat setting. Is someone else driving the car (like a spouse)?
I just googled and found that thanks. I do use the memory seat, but maybe since it's a new car I have to pair my key fob also, which I haven't done yet?
That's correct.
Adjust your seat position to where you want it, then the HUD height, and then set your seat memory (button 1 or 2, whichever you choose). You can also program the fob the same way. Adjust your seat position and HUD first, then program the fob. The HUD position will then revert to the proper height when you use the fob or the memory seat button.
Latest posts
