Headlight wont work
georgescott
Hi All, I have a problem with my right front low beam. I thought the bulb was out but I tested it and it is fine, checked the fuseable link and it was also fine (switched it with the left one). Wiggled jiggled and jostled any connector I could Am at the end of my rope. Any help is appreciated. Scott
If you've got a 2006-2010 Mazda5, then I would suggest looking at this headlight bulb socket that sits between your low beam bulb and your headlight electrical connector. I had this same issue with my wife's 2008 Mazda5 and the new socket cured that problem. The bulbs on the 2012+ models have the electrical connectors built-in and don't require this socket.
https://www.amazon.com (commissions earned)
