the HID's im using actually run less wattage than the standard halogens and as for the wiring, if you look at my pictures on my other post in the OEM projector thread you can see the 2 silver ballasts in the kit, these do all the power converting, they dont take any power from the cars wiring, it has a direct + connection to the battery with its own fuse, and has 2 earth connections to the chassis, the only connection it has to the cars wiring is from the bulb cable so it comes on when i turn the lights on from the cabin, so no need to worry about heating the wires oh and as for the temp of the bulbs again check out my pics they are encased in their own heatshield completely protecting the headlight casing.
Basically it has its own circuit so you dont fry the cars electrics (breakn)
You would probably have more chance of frying wires using more wattage in the bulbs tbh, drawing more power, creates more heat?
