It isn't aim. It's the reflector design that scatters the beam and causes excess glare even when light output is reduced for DRLs. Toyota and Honda have the same issue in some modelsYeah that's probably what it is. If the headlight isn't aimed properly, in configurations like that, both low beams and DRLs will be affected since the only difference between the two is the intensity.
