Focuz_Freek_XxX
Ok here is the deal. I am wanting to increase handling but am fairly new at the whole suspension game.
What would be better a lower center of gravity and less lb/in spring rate
OR a higher center of gravity and more lb/in spring rate?
Note: Adjustable struts will be used with the springs.
J
The reason i ask is the progress springs are relatively low on the rates but offer a lower ride height than say the eibach pro kit springs with a higher rate with less of a drop.
J
