Haltech Library..
LinuxRacr
Contributor
2001 Mazda MP3
I thought it was about time for a Haltech Library... Post your maps here in this thread (if you can).
It's running, but..
Oops, I posted this in the wrong thread...but it's my thread!! (evil)
That's right, it started up on the 1st try!! It ran rich as hell until Juan over the phone told us how to adjust the fuel map. Ahamad made the changes. After we got it running smoother, we drove around the corner to the gas station to getr some gas. While driving around doing some mile tuning, I noticed a nice sputtering-pop that kind of eractically. The more I drove, the worse it got. I drove the car home all the way to Arlington with this lean pop sputter. The A/F ratio's were well in the safe range, and I didn't boost. The thing that was interesting is that my Passport 8500 was reporting voltage reading higher than I've ever seen...like as steady 15 volts, spiking to 16 volts wich brought on the high voltage warning. I couldn't step on it. Monitoring the Haltech Gauges, I notice that when a pop was big enough, the RPM's would jump to redline and back down, while the stock Tach was steady. Everytime I would step on the gas, and bring the revs up on the highway, the high voltage alarm would come on. Why is my voltage so high?
use a relay to get a clean source from the battery
otherwise when you use any acessory the haltech does some funky stuff
we also opened the screw on the throttle body a little bit as well, don't forget that.
haltech
ok... so im TRYING to figure out what ems to run.. im looking into the e8 but i dont know... what do ya'll recomend..???
p5 stock turbo.... going to be upgrading turbo, mani, and down pipe.... internals also
I wasn't aware that P5's came boosted....
Nevermind, I see your sig...
E8 has more options, but the E6X is what I run.
Hey guys, I've got an E6X that I'll be running on my 1.6L. Will I be able to use the maps on this thread as a starting point or do I have to start from scratch? Thanks!
any body knows a map that i can possibly use with this mods:
vibrant J back exhaust
440cc injectors
CAI
walbro FP
gt28rs
10psi
and haltech E6X soon!
Stock Injectors
walbro
GT2871R Turbo
15-20 psi
HKS Blow Off Valve
aem fuel pressure regulator
PERRIN Fuel Rail
haltech E6X
626 manifold
Forged Engine Internals
PERRIN Front Mount Intercooler
Injen Cold Air Intake
WELDED (LSD)
Exedy Stage 2 Track Clutch
Fidanza 7.5 lb Light Weight Aluminum Flywheel
I hope I can get one next week with 850 cc injectors
