I searched, no luck...
I'm SO close to having my P5 back on the road. I was close enough at one point that I almost had everything put away, all I was doing was filling the transmission. When I got to the 3rd qt, however, I checked under the car (as I had been doing every so often) and I started to see a leak...
Background
I've been in the process of changing the front wheel bearings over the past three weeks (don't ask why it has taken so long). I had to use a 3-pt press and an impact to get the half shafts out of the hubs. To do that, I had to pull the half shafts from the transmission.
In the process of trying to remove the drivers half-shaft from the hub I f'ed up the threads. Not too expensive, rebuilt was $60 at O'reilly's including core return.
I also bought new output shaft seals for the transmission just to change them out. However, in trying to pry the passenger side out, I gave up, couldn't get it out, returned them both.
At first I thought maybe I had messed up one of the old output shaft seals, so I pulled out all of the tools again and tore the thing apart. This time the half-shaft easily slips in or out of the hub so I pulled it all apart and start trying to figure it out.
I realize the new half-shaft just isn't "clicked" in all of the way. So I fight and I fight and I fight and I cannot get this thing to snap in. I pull it out, and try to bend the snap ring a little more together, I don't think it moved at all. I try lubrication with fresh transmission fluid, still no luck. I try just a slight bit of grease, no luck. I pull the strut/spring assembly out so that I can get a more direct-push at it (instead of at an agle) still no luck.
Finally I gave up, threw the new wheels (17" Mazda 3 wheels, stock BFG 205/50/17) back in the roomies 4Runner and went to have them fixed (no valve stems, previous owner took out the pressure sensor stems and put them in new wheels). $6.56 is all Gateway charged me when I picked them up. We'll see if they are still balanced if I ever get the half-shaft to click in. The rear bead was not "broken" so as long as there wasn't too much of a weight difference between the pressure sensing stem and the non, I should be good to go. Well, except the tires might be tooooo tall in the back, there isn't much room between the tire and the bottom of the strut.
Anyway, reason for post is HELP! WHY the F wont this half-shaft click in!?!?!
Background
