Chris_Top_Her
Contributor
- San Antonio, Texas
- '15 CX-5 Miata AWD
Before
After
After
This thread (http://www.mazdas247.com/forum/showthread.php?123816937-H-amp-R-lowering-springs) will tell you pretty much everything you need to know about limitations of using lowering springs on CX-5. The camber issue is the reason some here, including myself, have given up the idea of lowering the car. At least until someone comes up with an aftermarket fix.factory camber is non-adjustable? ugh
*facepalm*
I really didnt expect that from Mazda
(btw, your alignment settings have nothing to do with the width of your tires)
Not listed on their web site.Has anyone looked at the Cork Sport camber kit? I see it's listed in one of the articles on the CJ Wilson lowered CX-5 by ProParts.
Should it be okay to lower just the rear and not the front?
Before
After
Chris… love the look. Did you have to do an alignment after install the lowering springs?
Before
Yes, as is the case with any ride height adjustment. You will not be able to get factory camber, however using coil overs (there are 2-4 options out there) you can. No problem for me because I am happy with my slightly more aggressive alignment and my wheels are wearing great, despite fast curves and the occasional slide.
Awesome - sounds like a reasonable compromise. How is the ride compared to stock springs?
I'm really debating on either getting larger wheels/tires vs lowering springs + stock wheels.
I wonder if I can run 265/45-20 and not rub if I don't lower?
That Tampa guy is running 10" wheels (TSW MAX A20x10x40 (ET40) Tires 275x40x20), not lowered and if I recall correctly he is not rubbing. I know if I were to install 10" wheels I would rub the inside plastic lining on average left/right turn say from a stop sign or something. In reality, it would not be a big issue because eventually it would wear down enough to not rub, or simply but the very small spot where it rubs. You could always add some kind of extruded patch to keep the water splash out (although really any water that got in would simply drain out of the plastic skid plate). Personally I purchased my wheels/tires local; I had no worries and what they recommended (tire size/ rim width combo wise) was a good fit.
Thank you! I might buy 20x8.5" wheels w/40 offset and get 275x40x20 tires...sounds reasonable.
If that doesn't work, I could try 265 or 255x45x20
