Brian MP5T said:
Brian MP5T said:I Ploted the GT-28RS on a FS engine running 7000 RPM. The RS is the "Sweet Spot" Check out the Blue Dots... They represent worst case senario...
The Red is the T-25 on the MSP...
How do you come uo with 7,000 rpms?
Brian MP5T said:Full crank Balance with Flywheel, Alignhoned, stronger wrist pins, no rev limiter...Reinforced Mains...
I wanted to plot the graph at worst case senario, if you re plot it for 6500 the dots actually appear to run down the middle.
MPNick said:Keep in mind that a reworked GT25R MSP turbo will make over 300whp and well over 325 foot lbs of toruqe to the wheels.
Brian MP5T said:I understand that there is more to be had out of a T-25, but the jump to a GT-28rs will yield a slightly higher boost threshold (300 RPM Differnce) with a FAR BETTER effency rating. Basically, take any T-25 and run it at 20 PSI, it will have to spin much faster and blow hotter than a Shelf GT-28RS. Peroid.
The GT-28RS makes more boost, colder at the loss of 300 RPM later spooliing.
Money in the Bank. The Bearing will last longer, the engine wil be less likely to detonation, and your FMIC will cruise allong rather than work overtime...
The Disco is not required for high HP, but if you are spending the money to make an engine that can hold 20+ Psi, drop a grand and get a RS at the same time...
FSDET said:why are u gonna spray water ? u have a good IC and ems.. is there a need for water also ?
wicked said:fsdet-I'm still going to spray,because it helps cool combustion chambers,allowing you to boost more.it also acts like a EGR,only better because water will expand better when heated than nitrogen.
fast lane-going to MAP,sorry didn't add everything into the list,theres still a lot more.
is 80mm close to 4"?I don't think it would work with my intake.I'll try to post some pics later.
