grounding kit
MSP#735
2005 Acura TL
ok so here is 1sty's grounding kit 90% installed....definately smoothed things out, esp when the A/C or defrost is on, great product!
last few.... (cheers)
Looks nice! How was the install? Are these still available?
Or does someone make something similar?
meh..it wasnt too bad, right now im kinda stuck with the negative terminal....i took my time and it took maybe 30 min, i cleaned as i went to, im anal like that. as far as still being made, no they arent but keep your eye out they are sold alot on here, there are other grounding kits but i have no experience with them....
If you ask 1sty I bet he can make you up a grounding kit. Last I heard he only makes them per request. He doesn't do it in mass production anymore. Plus the price might be higher now.
Thanks! I will try to PM him. The kit definately looks good!
ok so i havent completely installed the kit, i installed everything BUT the negative terminal....my lights however still cause a dimming when rolling up the windows but doesnt stumble when turning on the a/c or defrost...will the negative treminal grounding eliminate the dimming of the lights when rolling up the windows?????? here is a pic of the terminal set up i will be using...
