Grill 4 P5
if i were use the stock grill and cut a piece from another grill so i can match the bottom with the top. Is there any problem with the fitting?
I think there was a how-to on that in the how to section...I may be wrong.
yah supposedly dealers have the lower stock grill pieces for 20-30 bux and then you have to use a dremmel to shape it to it fits properly in the top section, count on at least a few hours of dremmel work to do a good job.
Other thing you could do if you just want the mesh instead of the stock grill is just make some that cover the originals, like hawaiinnights did with his lower grill do with both. I know the wings west mesh looks pretty nice.
Subghetto said:
I have the Autoexe CF grille with a mazda emblem on it.
Yeah since DGM ripped off the AutoEXE design, try not to call it an AutoEXE grill, cause it isn't. It's a DGM CF Grill, AutoEXE replica, if you want.
I still have the mesh pieces that used to be over the stock grill....looks just like the lower one but is not one piece because it goes around and in the middle emblem as well.
